Items
KIA Cee'd Sporty Wagon
Door: Peterrrrr · 14-05-11 -
KIA Kia Carens (nieuw model)
Door: KiaSportageVriend · 03-01-13
Laatste activiteiten
245
Handige en Leuke Gadgets voor de Sportage 5
HEADS UP AND WARNING TO THOSE WHO BOUGHT THE FITCAMX I bought the camera and installed the front a few weeks ago, just yesterday I installed the rear one (I didn't have time before). This morning I got hit from behind at a traffic light (3 week old car, 1200 km on it). When I checked the cameras I saw that the front cam barely caught the crash (luckily at least it caught it), the rear cam didn't, it cut off around 10 seconds before the crash so it didn't catch anything. The crash wasn't so strong to activate the G sensor so it didn't lock the video. When I got home I tested it a bit more and I noticed that when you turn off the car the last 3-4 seconds of the video from the front camera and the last 12-14 seconds from the rear camera before shutting of the car are not saved! When I got hit, after a few second I turned off the car and went out to see the damage. When I turned off the car it shut of the power to the camera and therefore it didn't save those last few seconds. Also, if you press the snapshot button and then turn off the car it again doesn't lock the video. I think the snapshot button only locks the video when it normally ends and then locks it, but not immediately so if you turn off the car after pressing the snapshot button it will not lock the video immediately. Therefore, if you are in a crash, WAIT 20-30 SECONDS BEFORE TURNING OFF THE CAR, or even better leave it on if possible. I will try to reduce the front video quality a bit and try a new memory card to see if the delay will be smaller. -
6
Kia Niro EV MY24 Digital Key
Weet je, een auto sleutel heb ik altijd bij me omdat die aan mijn sleutelbos zit. Als het werkt via een app is het gewoon een leuke gimmick. Anders druk ik alsnog op het knopje van de deur om hem te openen. -
6
En dan sta je naast de auto met je telefoon te knoeien omdat Kia Connect er uit ligt........krijg je de auto niet open. Net als wanneer er (storing) geen bereik is voor je telefoon. Dan kun je niet eens naar huis bellen of ze je de sleutel kunnen komen brengen. Ik ga ervan uit dat je dan toch beter de sleutel bij je kunt hebben, dus wat brengt zo'n 'gimmick' extra? -
24
Netwerkfout bij het openen van Kia Connect (iOS 16)
Dat is in elk geval hoopvol. Je zou eens moeten kijken of dit nog steeds werkt nadat je de auto 24 uur of langer niet hebt gebruikt. Ik krijg helaas nog steeds de bekende 997 foutmelding. -
6
Oh wow, dat zou te gek zijn. Niet dat het nu echt nodig is, maar altijd leuk om te gebruiken. Afwachten dan maar en we zullen het zien of het dit jaar gaat gebeuren. Voorlopig heb ik problemen met Kia Connect, hopen dat dit eerst opgelost kan worden. -
Blindspot ervaring Xceed/proceed
Beste, Ik ben aan het kijken voor een Xceed met o.a. de optie blind spot. (Reeds ook testrit gemaakt in Proceed met die functie maar gekozen om toch voor een Xceed model te kiezen.) Uiteindelijk testrit(ten) gemaakt, en mij viel op dat de herkenning/activatie van de rechterzijde minimaal tot niet is bij bijv. inhalen op de snelweg. Linker spiegel werkte conform zoals ik het verwacht. Mij ervaring van deze functie is alleen een mercedes en BMW. Hierbij was de functie in beide spiegels veel "adequater actief " zoals de linker spiegel van beide modellen. Bij de testrit heb ik het alleen bij de proceed 1x kunnen opwekken (van de 2x) door naast een vrachtwagen te gaan rijden en knipperlicht aan en beetje insturend naar de vrachtwagen. Mijn vraag is: Wanneer je bijv. iemand inhaalt op de snelweg, gaat dan ook je rechterspiegel knipperen als die in de dodehoek zit. (net als de linkerspiegel als een auto jouw inhaalt wanneer je rechts rijdt)? Het lampje werkt overigens wel...(Bij uit/inschakelen lichten wel de lampjes op in de spiegels) Ik kan wel inkomen dat het software matig anders uit kan zien bij kia....dan andere merken. Vind het gewoon opmerkelijk dat die rechts niet "continu" werkt.* Ik heb ook de betere scantools...en kennis maar dan moet ik evt inloggen onder betaling bij kia om de werking van het systeem uit te pluizen. Systeem is geen must natuurlijk...maar het moet wel de aanvullende werking hebben ondanks dat ik zelf ook moet opletten. *ik lees ergens snel, dat er misschien wat meer snelheidverschil moet zijn...of wat zegt de manual hierover? -
6
Volgens KIA Nederland is dit nog niet mogelijk. Het schijnt dat er dit jaar (?) een software update beschikbaar komt waarmee het wel mogelijk wordt gemaakt. -
Automaat ProCeed 2021
Goedemorgen, Heeft mijn Proceed ook, vooral van de derde naar de vierde versnelling. Hangt ook af van hoeveelheid gas / toeren en of de automaat koud of warm is. Ik merk het meer als de auto pas korte tijd rijdt. Of het kwaad kan: geen idee. Zal het eens melden bij de Dealer bij de volgende beurt. Km-stand 71000 Verstuurd vanaf mijn Pixel 7 met Tapatalk -
24
Vanmorgen, vrijdag 19 april om 06:35 uur, 1e keer opnieuw gekeken en hij deed het direct. Goede informatie en ook bij het opvragen geen probleem. Zo ging het gisteren ook, straks nog maar eens opnieuw kijken, en ik ga tellen hoe vaak ik de app gebruik. -
Just in time for the Playoffs, Kia's in-car NBA Display Themes lets Basketball Fans Showcase Team Spirit
EV9 owners will soon be able to personalize their vehicle’s cockpit with their favorite NBA team’s colors and logos Display Themes will initially be available on the EV9, but are expected to... Bekijk volledig artikel
Forums
Kia Modellen
- Android radio key 1 en 2 aansluiten op stuur wiel bediening
- Laatste antwoord door Moniquesummergirl,
Niro
- 34,2k berichten
- 29 volgers
2016 -> heden
Discussies, Vragen en Weetjes over de Niro vind of plaatst u hier
- Kia Niro EV MY24 Digital Key
- Laatste antwoord door ElectricKia,
EV9
- 1 bericht
2023->heden
Discussies, Vragen en Weetjes over de EV9 vind of plaatst u hier
- EV9 toegevoegd aan het forum
- Laatste antwoord door xtra40,
- Carens: Opbergvakken in vloer drijfnat. Rest van de vloer is droog. Iemand ervaring mee?
- Laatste antwoord door sennah,
Sportage
- 32,2k berichten
Discussies, Vragen en Weetjes over de Sportage vind of plaatst u hier
- Handige en Leuke Gadgets voor de Sportage 5
- Laatste antwoord door Z61,
Sorento
- 9k berichten
Discussies, Vragen en Weetjes over de Sorento vind of plaatst u hier
- Reserve wiel verdwenen
- Laatste antwoord door HKiaSor,
Optima
- 336 berichten
Discussies, Vragen en Weetjes over de Optima vind of plaatst u hier
- Storing HEV in display
- Laatste antwoord door Mark Post,
Stinger
- 34 berichten
( 2017 > heden )
Discussies, Vragen en Weetjes over de Stinger vind of plaatst u hier
, Vragen en Weetjes over de Stinger GT vind of plaatst u hier
- kia Stinger gt 2020 of proceed gt kopen?
- Laatste antwoord door JaapW,
Concept cars
- 89 berichten
Discussies, Vragen en Weetjes over Concept modellen vind of plaatst u hier
- FUTURON
- HABANIRO
- IMAGINE
- Pro Ceed
- Telluride
- Novo
- SportSpace
- Trail'ster
- KX3
- GT4 Stinger
- Provo
- Cross GT
- Niro
- Cub
- Trackster
- GT
- Naimo
- Kv7
- Pop
- Ray
- N.3
- Ked.5
- Soul'ster
- Koup
- Kee
- Kue
- KND-4
- Ex_cee'd
- Pro Cee'd
- Cee'd
- Soul
- Multi-S
- Mesa
- Mohave
- Kia Sport
- KCD-1
- KCV-1
- KCV-2
- KCV-3
- KMS-2
- KMS-III
- KMS-4
- KMX-02
- KMX-3
- KMX-4
- KMX-90
- KEV-4
- Genesis
- Adres knop weg
- Laatste antwoord door Markelx,
Buitenlandse modellen
- 111 berichten
Nieuws KIA Motors Nederland
- 1,6k berichten
- Persberichten van Kia Motors Nederland.
- Laatste antwoord door KCG,
Te koop aangeboden / gevraagd
- 26 berichten
- 3 volgers
- Te koop. 17" winterset
- Laatste antwoord door pdakkerman,
Nieuwtjes Kia Club Nederland
- 9,7k berichten
Hier vind je alles over de veranderingen die op het forum worden uitgevoerd
- Reklame popup
- Laatste antwoord door Murcielaygo,
Kia nieuws
Kia wereldnieuws
- 1,1k berichten
Kia global mediacenter nieuws
Korean Car Blog
- 727 berichten
Korean Car Blog publiceert artikelen over Koreaanse merken waaronder Kia
- Stinger EV Replacement GT1 Project Could Have Been Canceled
- Laatste antwoord door Kiaclub Nieuwsrobot,
Kia Buzz
- 1,1k berichten
Kia BUZZ is Kia's officiële blog voor het delen van informatie over Kia voertuigen, nieuws, informatie en adviezen. Kia BUZZ is geschreven door een breed gamma van Kia deskundigen en managers vanuit de hele organisatie om zo te helpen Kia dichter bij haar klanten, het bedrijfsleven industriële opinieleiders en auto liefhebbers te brengen.
- KIA EV9 in het wild in NL.
- Laatste antwoord door Justdigit,
Kia World
- 1,4k berichten
Een rss feed van deze website met veel nieuws over KIA modellen.
- Happy New Year 2022
Kia Video's
- 123 berichten
In dit forum kan je internet video's plaatsen die met KIA te maken hebben.
Kianieuws van Autoguide.com
- 757 berichten
Lees de laatste nieuwtjes over KIA van deze grote autosite.
Verslagen / Verhalen / Dagboek / Café
Kiaclub Café
- 12,2k berichten
- 2 volgers
In het Kiaclub café kan je alles kwijt wat niet met Kia te maken heeft.
Leden Garage forum
- 1,7k berichten
In dit forum worden automatisch posts geplaatst vanuit het garage component.Wanneer iemand een nieuw voertuig in de garage zet wordt er een nieuw topic in dit forum gemaakt. Je kun hier dus alleen reageren op topics.
- Auto: KIA Sportage 5 (2021 -> heden)
- Laatste antwoord door Aldert Piersma,
Dagboek van Kia rijders
- 2,4k berichten
Plaats hier alles over uw Kia, zoals type, motor, kleur, accessoires en alles wat er aan verandert is.
- Rio van Drieoog
- Laatste antwoord door Drieoog,
Accessoires / tuning / techniek
Alles over accessoires, tuning, techniek, enz. in het algemeen.
- OBD2 tool om settings te wijzigen?
- Laatste antwoord door elsinga,
Audio / Navigatie
- 2,7k berichten
- 2 volgers
Discussies, Vragen en Weetjes over Audio/Navigatie/multimedia vind of plaatst u hier
- Ceed LG 2-din navigatie modden
- Laatste antwoord door KiKiHUN,
Technische Problemen (Particulieren)
- 3,6k berichten
- 1 volger
Tips en antwoorden op vragen en handige weetjes; doe er je voordeel mee!
- Tankklep sluit niet mooi af, nieuwe sportage 2022
- Laatste antwoord door Markoes,
Car Cleaning
- 1,9k berichten
Alles over het poetsen en schoonhouden (schoonmaken) van je Kia.
- Schade na parkeren P4 Eindhoven Airport
- Laatste antwoord door Ludo Nieste,
Nieuwe leden / evenementen
Nieuwe leden / Introductie
- 15,6k berichten
- 4 volgers
Nieuw op het forum? Stel je even voor!
- KCG zoekt nieuwe leden.
Wie is er Online 4 leden, 0 Anoniem, 82 Gasten (Bekijk HIER de volledige lijst)
