xtra40
Ray
Aanbevolen berichten
RAY
Aircraft-inspired design. Earth-friendly efficiency.
Being green doesn’t have to be an obvious statement anymore. The stylish, aerodynamic Ray Plug-in Hybrid Concept combines design and engineering for maximum efficiency. Touch-screen controls, drive-by-wire steering, cool-glazing solar glass and a lithium-polymer battery help make this futuristic four-seat compact sedan efficiently functional and striking in appearance.
The first Kia to include solar panels.It’s made from both lightweight and recycled materials—both of which contribute to the Ray’s distinct look. But it’s the materials in the roof that are most remarkable. Embedded in the glass roof panel are solar cells that power extra lighting and climate control systems.
The Ray also features technology that helps cool the car. Nano-laminate film and cool-glazing materials work to reduce the solar heat. And when the vehicle is parked, the solar panels provide a charge that operates a cooling fan that helps reduce the interior’s temperature.
Features & Specs
DRIVING FUNCTIONS:
  • Engine: 1.4-liter Gamma 153-hp GDI engine / 78-kW electric motor
  • Transmission: CVT / fixed ratio
  • Batteries: lithium-ion polymer
  • PERFORMANCE:
  • Top Speed: 109 mph
  • Fuel Economy (Pure HEV Mode): 77.6 mpg
  • Fuel Economy (Plug-in HEV Mode): 202.3 mpg
  • Vehicle Range: 746 mi.
  • Cd (Coefficient of drag): 0.25
  • Steer-by-wire system
EXTERIOR DIMENSIONS:
  • Length: 173.2 in. / 4,400 mm
  • Width: 72.8 in. / 1,850 mm
  • Height: 53.5 in. / 1360 mm
  • WHEELS & TIRES:
  • Wheelbase: 106.3 in. / 2,700 mm
  • Tires: 195/50 R20 low-rolling resistanc
Deel dit bericht
Link naar bericht
Delen op andere sites
Hoeveel gallons passen er in die tank....
Deel dit bericht
Link naar bericht
geen idee maar je komt zat ver op 1 gallon als ik het verhaaltje zo lees  :-)  :-)
Deel dit bericht
Link naar bericht
Maak een account aan of log in om te reageren
Je moet lid zijn om een reactie te kunnen achterlaten
Account aanmaken
Maak een account aan in onze gemeenschap. Het is makkelijk!
Registreer een nieuw account
Aanmelden
Ben je al lid? Meld je hier aan.
Nu aanmelden
Belangrijke informatie
Door deze site te gebruiken ga je akkoord met onze Gebruiksvoorwaarden.
