Administrators Jheroen Posted August 23, 2005 Administrators Posted August 23, 2005 Analyzer Results:Analyzing URL: http://www.kiaclub.nl/ The keyword density of a Web page is now considerd the most important part of search engine optimization. Below are the results fetched from the Web page listed above. From here you can instantly submit this page to several search engines for free, but before you submit you should make sure this page is truly "search engine friendly". The BIGGEST mistake submitter's make is submitting a Web page that is not search engine friendly. Tip - If you're serious about promoting your Web site you should become a member. All members receive unlimited access to our Web Page Analyzer and they can submit to many more TOP search engines for free using Easy Submit than non members can. -------------------------------------------------------------------------------- WARNING: This page appears to be a framed Web page. While frames can be great for browsers, it is not usually designed properly to be search "engine friendly". If you receive errors below stating no TITLE or META Tags found or the information found is not what you expect it to be, it is most likely because the page does NOT contain this information, the Tags are not used properly or you are analyzing the main frameset and not the actual page that contains these Tags. ONLY those who fully understand the use of frames and how to build a "robot friendly" framed based Web site should use them. We explain ways of using and building "robot friendly" framed based Web sites in our member's area. What is presented below is what robots will find when visiting the URL you submitted. -------------------------------------------------------------------------------- TITLE Tag Analysis Current Page Title: <TITLE>Welkom op de website van Kia Club Nederland !</TITLE> This Tag is 45 characters in length including tabs, spaces and carriage returns Status: This Tag is considered acceptable and search engine friendly. However this Tag may or may not be properly optimized or descriptive enough to put your Web page on the top of the search engines. This Tag should contain keywords and keyword phrases that is important to your site. Our recommended maximum number of characters for this tag is 60. -------------------------------------------------------------------------------- META Description Tag Analysis Current Meta Description Tag: WARNING! This Tag is NOT being used or used incorrectly. See source below. Consider using our free META Tag Builder This Tag is 0 characters in length including tabs, spaces and carriage returns WARNING! This Tag is NOT being used or used incorrectly. See source below. Consider using our free META Tag Builder -------------------------------------------------------------------------------- META Keywords Tag Analysis Current Meta Keywords Tag: WARNING! This Tag is NOT being used or used incorrectly. See source below. Consider using our free META Tag Builder - Note - If you want to know the best keywords for your meta tags . This Tag is 0 characters in length including tabs, spaces and carriage returns No words were repeated more than 3 times WARNING! This Tag is NOT being used or used incorrectly. de tags staan er wel maar worden verkeerd gebruikt waardoor zoekmachines de woorden en omschrijving er niet uit kunnen filteren. Ook de zoekfunctie zoals hier omschreven: <meta name="ROBOTS" content="index,follow"> zou index,all kunnen zijn; hiermee zoekt de machine alle html door waardoor er dus weer meer gelukte zoekacties en dus hits gegenereerd kunnen worden. tevens <meta name="REVISIT-AFTER" content="1 week"> zou ook op 1 dag kunnen staan, zo gaan actuele berichten en nieuws direct de zoekmachines in. Zo maar even een klein onderzoekje levert al dingen op die bijgesteld kunnen worden, wil je immers gevonden worden dan is dit erg belangrijk. Quote
Administrators Jheroen Posted August 23, 2005 Author Administrators Posted August 23, 2005 en dit levert de check op bij de forumlink: <HEAD><meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1"> <meta http-equiv="Content-Style-Type" content="text/css"> </HEAD> voor de html kenners is te zien dat deze waardes geen zoekmachine kunnen voeden, linken linken linken dat is vaak het antwoord op veel hits, maar wel beginnen bij het begin en dat is de site zelf. het gaat zeker goed komen! Quote
