VSM pakket niet gemonteerd
ik heb precies hetzelfde. kia aangeschreven, dealer op de hoogte gesteld, brief van kia waarin ze fout aangeven. dus wat nu?
Thanks, do i have the Hillstart?
Where did you get this information from, a site?
Hoi, ik zie m er tussen staan,589HA1 HAC (HILLSTART ASSIST CONTROL dus gefeli
Yes, you have HAC
589HA1 HAC (HILLSTART ASSIST CONTROL)
Information is paid.
Ik zou graag mijn VIN-nummer ook uitgelegd zien: KNADN511AC6020327
Alvast bedankt!
STANDARD
0091B6 ENGINE PACKAGE - DCVVT
2841B7 EMISSION REGULATION - EURO 5
2843A9 EVAP. GAS CONTROL - EURO-5
2865A2 MUFFLER MATERIAL - SUS
3111C7 FUEL TANK - CAPACITY - 43 LITER
3115A2 AUTO FUEL CUT SYSTEM - CRASH
371CA1 BATTERY SAVER
4161A2 CLUTCH TYPE - HYDRAULIC
4371A1 MT KNOB - SOFT PVC
4501A1 CLUTCH LOCK
4502A4 CLUTCH SW
4951E6 LH/RH - TJ21+BJ21
5291B5 STEEL WHEEL - 5.5J * 15
5293DB 185 TIRE - 185/65 R15
5295A3 TIRE MATERIAL - LRR
5296C1 FULL SIZE WHL COVER - A TYPE
529AB1 TIRE PRESSURE LABEL - EUROPE
529TA6 TOOL SET & JACK LABEL - GENERAL
5411A1 FR SUSP TYPE - MACPH. W/COIL SPRING
5511A9 RR SUSP TYPE - TORSION AXLE
5611B2 3-SPOKE - POLY URETHANE
5631A4 STEER`G COLUMN-MANUAL TILT & TELESCOPIC
5691A3 DRIVER SIDE - DEPOWERED
5692A3 PASSENGER SIDE - DEPOWERED
5693A3 SIDE AIR BAG-FR - FR(THORAX & PELVIS)
5695A1 CURTAIN A/BAG
569BD1 PASS`S - A LANGUAGE
569EA1 PAB ON/OFF SWITCH
569JA1 PAB ON/OFF LAMP
569KA1 SIDE IMPACT SENSOR
5711A5 MDPS-DC
5811A3 FR BRAKE - DISC-14 INCH
5812A7 RR BRAKE - DISC-14 INCH
5891A2 ABS (ANTI LOCK BRK SYS)
5894A1 ESC (ELECTRONIC STABILITY CONTROL)
5911A2 SINGLE BOOSTER - 9 INCH
6501A1 HIGH GRADE
8131A1 CENTRAL DR LOCK/UNLOCK - DR`S CONTROL
8135A3 INSIDE HNDL OVER RIDE - ALL DR
813AA1 SPEED SENS`G AUTO DR LOCK
813BA1 IMPACT SENS`G AUTO DR UNLOCKG
813DA1 IGN KEY REMINDER
8152A3 FUEL FILLER DR REL TYPE - CABLE
8171A1 TAIL GATE TYPE - LIFT UP
8176A2 TAIL GATE O/SIDE HANDLE - BODY COLOR
8177A1 CENTRAL T/GATE LOCK/UNLOCK
817AB3 TAIL GATE FINISH`G-FORMED TYPE(PLASTIC)
8191A2 KEY TYPE - INSIDE CUTTING
8192C3 TX-INKEY TYPE - TX 2EA
8194B3 TYPE - FOLDING
8195A1 IGNITION ILLUMINATED - BULB TYPE
819AA1 KEYLESS ENTRY-B/ALARM
819CA1 KEYLESS ENTRY-T/OPEN
822AA1 DR BLACK OUT MATERIAL - TAPE
8233A1 CENTER TRIM - PLASTIC(NO COVER`G)
8237A1 ARM REST HANDLE - PULL TYPE
8241A2 FR DR GLASS - TINTED
8261A2 FINISH`G - BODY COLOR
8262A3 LEVER FINISH`G - METAL PAINT
82A5A1 ***
82A7A1 MAP POCKET-RR DR
8347A1 SW ILLUMINATION(DR)
8348A1 SW ILLUMINATION(PASS`S)
834AA1 AUTO DOWN
834CA3 SAFETY WINDOW - FR DR(DRIVER`S)
8421D3 N/PUNCH - HIGH VELOUR TYPE
8446A1 POWER OUTLET(FR)
8451A1 W/O LOCK
8452A2 W/ DAMPER
845BA1 W/ ILLUM
8461A1 STD
8462A1 CUP HOLDER - FR(W/O ILL)
847BA1 W/O COVER
84B5A1 SMALL TRAY
8511B1 DAY/NIGHT TYPE
8521A1 MATERIAL - VINYL
8522A1 VANITY MIRROR - GLASS TYPE
8523A1 MATERIAL - VINYL
852BA1 VANITY MIRROR COVER
852GA1 VANITY MIRROR - GLASS TYPE
852HA1 VANITY MIRROR COVER
8531A2 ROOF TRIM MATERIAL - FABRIC
8532A1 FR - 1 EA
853AA2 RR - 2 EA
853JA1 RR - 1 EA
8571B1 LUGGAGE SIDE - PLASTIC
8572A2 RR - PLASTIC
8573A2 FLOOR - WALL PAPER
8578A1 LUGGAGE NET HOOK
858AA1 A PILLAR - STD
858BA1 B PILLAR - STD
858CA1 C PILLAR - STD
8591B1 COVER`G SHELF TRIM - WALL PAPER
8611B1 W/S GLASS TYPE-TINTED (W/O S/BAND)
8612A1 MLD`G-WINDSHIELD - BLACK
8631B4 B TYPE - BLACK+CR COAT`G
863CA2 GRADE - GLS
8641A1 TOWING HOOK
8642A1 TIE DOWN HOOK(LASHING)
8643A1 SHIPPING HOOK
8649A5 ID PLATE - EUROPE(`E` MARK) TYPE
8651B1 TYPE - 2.5 MILE
8652B1 COLOR - BODY COLOR
865EA2 FR BUMPER LIP - W/
871BA1 RR HEATED W/ TIMER
8722A4 H.M.S.L - T/GATE OTR
8765A2 COLOR - BODY COLOR
878AA1 FR QTR GLASS TYPE - CLEAR
8811C1 CLOTH - CLOTH
8821A5 HEAD REST - UP/DOWN & SLIDING
8823A1 SLIDING
8824A2 DOUBLE RECLIN`G
8825A2 ADJUSTER - HEIGHT ADJUSTER
8836A3 SEAT BACK PNL(W/POCKET)
8854A5 HEAD REST - UP/DOWN & SLIDING
885DA1 SLIDING
885EA2 DOUBLE RECLIN`G
886BA3 SEAT BACK - SEAT BACK PNL(W/POCKET)
8881B1 DRIVER`S SIDE - ELR
8884D1 PASSENGER`S SIDE - ELR
8885A2 RETRACTOR PRETENSIONER - ELECTRICAL TYPE
8889A1 SEAT BELT REMINDER
888AA2 PRE TENSIONER - ELECTRICAL TYPE
888DA1 SEAT BELT REMINDER
888EA1 LOAD LIMITER
888KA2 S/BELT ANCHOR - ADJUSTABLE
888RA2 S/BELT ANCHOR - ADJUSTABLE
889MA1 LOAD LIMITER
8912D1 6:4 SPLIT BACK FOLD`G - BACK
8913A1 LH
8914A1 RH
8915A1 CTR
892DA1 HOLDER - UPR ANCHOR
892GA1 LWR ANCHOR
8981A4 SIDE - ELR
8982A4 CTR - ELR
898JA1 S/BELT REMINDER
921BA1 LEVELING DEVICE - MANUAL
9222A1 RR - CONVENTIONAL
9231B1 INTEGRATED - CLEAR LENS
923DA1 ONE TOUCH TRIPLE TURN SIGNAL
9287A1 LUGGAGE LAMP
928FA1 CTR - GLOW LAMP
928KA1 DELAY OUT INTERIOR LAMP
928WA2 BULB TYPE - 2 BULB
9340A1 MULTIFUNCTION SW TYPE - LHD
9401C1 CLUSTER TYPE - CONVENTIONAL
9402A1 SPEEDOMETER
940AA1 TRIP ODOMETER - NORMAL
940BA1 TACHOMETER
940CA1 FUEL
940DA1 WATER TEMP.
9451A1 TYPE - DIGITAL
9452A1 OUT DR TEMPERATURE
9491A1 RHEOSTAT
94C6A1 DIRECTION INDICATOR
94C7A1 OIL PRESSURE
94C8A1 BRAKE OIL
94C9A1 PARK`G BRAKE
94D0A1 DR AJAR - DR AJAR
94D1A1 BATTERY CHARGE
94D2A1 HIGH BEAM
94D3A1 LOW BEAM
94D4A1 LOW FUEL
94D5A1 RR FOG LAMP
94D7A1 TRUNK LID(T/GATE) OPEN
94D9A1 CHECK ENGINE
94E3A1 SEAT BELT
94E5A1 A.B.S
94E6A1 A/BAG
94H6A1 IMMOBILIZER
94H7A1 MDPS
94H8A1 ENG OIL LEVEL
94H9A1 E.S.P
94J0A1 E.S.P OFF
94M0A1 SPEEDOMETER TYPE - KMPH
94N0A1 TEMPERATURE UNIT - C
94P0A3 COLOR - FORM`G FACED
94X6A1 M/T SHIFT INDICATOR
9541A1 BODY CONTROL MODULE - BCM(ETACS)
9542A1 IMMOBILIZER
9611PK RADIO+CD+MP3+RDS+VSS - PA30A RV
9614B1 COMPONENT- 2 DIN
9615A3 FREQUENCY VIBRATION - AM9K/FM50K
9616A1 VOLUME KNOB TYPE - EUROPE TYPE
9618A1 USB+AUX
9621G1 ANTENNA TELESCOPIC - ANTENNA ROOF TYPE
963CA1 SPEAKER LOCATION FR DR - GENERAL
963ZA1 SPEAKER LOCATION RR DR LOW-GENERAL
965AA1 DISTANCE TO EMPTY(D.T.E)
965BA1 AVERAGE FUEL CONSUMPTION(AFC)
965DA1 ELAPSE TIME(E/T)
965EA1 INSTANT FUEL CONSUMPTION
9661A1 HORN - SINGLE
967AA1 AUDIO REMO.
9681A1 SEAT BELT
9684A1 KEY OPERATED WARN`G
968BA1 ACOUSTIC WARN`G
9711A2 BLOWER - 4 SPEED FAN
9714A1 FUNCTION - AIR FILTER
9721A2 CABLE TYPE - ROTARY TYPE
9741A1 RR HEATING DUCTS - 2ND SEAT
9761A1 FR COOLER - MANUAL A/CON
979EA1 EXTERNAL CONTROL COMPRESSOR
9811A2 FR WIPER - INTERMITTENT(VARIABLE)
9819A2 BLADE TYPE - AERO
981AA1 FR WIPER-2 SPEED
9871A1 RR WIPER - INTERMITTENT(NON VARIABLE)
OPTIONAL
3711C1 BATTER CAPACITY AGM TYPE - 60AH (20HR)
3731B1 ISG - STARTER TYPE
3734A1 L.D.C CONVERTER - 200W
5297C1 TEMPORARY - STEEL WHEEL & TIRE
5896A1 ESS (EMERGENCY STOP SIGNAL)
589GA1 VSM (VEHICLE STABILITY MANAGEMENT)
811AA1 HOOD INSULATOR
8245A5 RR DR GLASS - PRIVACY
8341A2 POWER WINDOW(FR+RR)
8349A1 SW ILLUMINATION(ALL)
8441A5 FR - PORTABLE
8445A1 CIGAR LIGHTER - W/O ILLUM.
845DA1 GLOVE BOX-COOLING
8712C2 BACK LITE GLASS TYPE -PRIVACY(W/ HEATED
8762C4 PASS`S SIDE - ELECTRIC HTD-CONV
8763C4 DRIVER`S SIDE - ELECTRIC HTD-CONV
876MA1 ELECTRIC FOLD`G CONTROL
876NA1 SIDE REPEATER LAMP (O/S MRR)
9211F4 PROJECTION - LOW BEAM-A TYPE (MFR STATIC
9213A4 DRL - DEDICATED LED TYPE
9219A1 AUTO LIGHT CONTROL
921LA1 LED POSITION TYPE
9221C1 CONVENTIONAL - PROJECTION
9241A3 LED TYPE
94G4A1 FOG LAMP (FR)
94X4A1 AUTO STOP (ISG)
C14 NETHERLANDS
Maybe it's time for a individual FAQ VIN topic.....!
Zoals gezegd in mijn reactie:
"Zij zouden iedereen die het VSM pakket, of onderdelen daarvan, mist moeten informeren en niet wachten tot de klant reageert."
Dit gaat dus niet over de bekende of incidentele gevallen, ook niet over de afwikkeling maar juist over de onbekende gevallen. Alle mensen die dit forum niet lezen en geen idee hebben moeten naar mijn mening ook geïnformeerd worden! Of behartigd de KCG alleen de belangen van diegene op dit forum???
Wij behartigen inderdaad alleen de belangen van de forumleden op de KiaClub. Wij willen natuurlijk best het één en ander voorleggen aan KMNL.
Maar, dat betekent dat er eerst een poll o.i.d. moet komen, zoals:
1. wie hebben geen VSM pakket op hun Rio?
2. wat is er reeds gedaan om dit te achterhalen (wel/geen dealerbezoek)?
3. welke oplossing of voorstel ligt er vanuit de dealer/importeur?
Als wij niet de nodige info hebben, staan wij natuurlijk ook met lege handen bij KMNL.
Dus wie van de Rio rijders wil het initiatief nemen om dit voor ons in kaart te brengen?
Wij zijn te allen tijde bereidt dit voor te leggen aan KMNL!
Zoals ik al zei, ik ben nog aan het wachten op mijn dealer. Als dit afgerond is of als ik niet tevreden ben met het resultaat, ga ik alle info en emails etc doorsturen aan jullie.
Je weet toch dat er verschillende auto's zonder VSM pakket zijn afgeleverd! Er zijn er ook genoeg die er nog achter proberen te komen op heuvels en zo. Er zijn zelfs forum leden die met hoge snelheid door bochten gaan om te kijken of ze wel ESS hebben.
De importeur kan iedere Kia Rio rijder zeer snel duidelijkheid verschaffen, ook al onze forum leden. Waarom wil het KCG dan dat ieder voor zich er achter probeert te komen of hij of zij wel of niet dat VSM pakket heeft? Waarom niet in het belang van onze forum leden het dringende verzoek bij de importeur neerleggen om de eigenaren zonder VSM pakket te informeren?
In je reacties op mijn berichten focus je alleen op de afhandeling. Dan heb je mijn bericht niet goed gelezen, mijn bericht gaat over het informeren, afhandelingen komen daarna, is ander onderwerp.
Snap echt niet waarvoor je daar een poll voor nodig hebt, maar zal proberen deze knop te vinden en er een te starten. Hoeveel voorstemmers moet ik dan hebben voordat er iets mee gedaan wordt? 1, 10, 100?
heb net van coolman mijn vin gegevens gekregen,
ik heb wel ESC ( das het belangrijkste )
maar geen VSM, HAC en ESS, die staan bij anderen die die systemen wel ingebouwd hebben tussen de lijst opties ( is bij mij al kleiner omdat ik comfort pack heb en geen superpack )
OPTIONAL:
C14 NETHERLANDS
Als ik antwoord terug heb van mijn dealer meld ik me weer!
KCG: Het is wel handig zo'n poll om dan duidelijk te zien om hoeveel leden het gaat en wie allemaal. dan kunne we in dat poll topic verdere stappen bespreken misschien?
Houden we het wel een beetje vriendelijk hier? Iedereen bedoelt het goed, maar als bepaalde berichten even niet goed worden begrepen is gelijk het hek van de dam. Kom op zeg, gedraag je eens minder vijandelijk en ga desnoods via PM met elkaar in discussie.
hmmm ik ben eens terug aan het lezen maar ik zie nergens iets vijandigs eigenlijk?
Je hebt gelijk, excuses, ik liet me te veel gaan in de discussie. Uiteindelijk bedoelt iedereen het goed.
Op 01-10 de brief van KMN ontvangen over de afhandeling ( die me nu wel bekend is 100 euro ) en op 05-10 een mail gestuurd naar de directie van de Kia dealer dat ik ze in gebreke stelt over dit probleem, tot nu toe van beide nog geen enkele reactie terug gehad, je gaat je steeds meer ongemakkelijker voelen.
.........tot nu toe van beide nog geen enkele reactie terug gehad, je gaat je steeds meer ongemakkelijker voelen.
Je mag niet van een grote organisatie verwachten dat ze binnen enkele dagen je brief beantwoorden. Je moet dus heel even geduld hebben. Ze kunnen er trouwens beter weloverwogen naar kijken, dan té snel een besluit nemen.
Gast Warmentuuter
Er is al meerdere keren gevraagd op een poll te maken.
Dan weet KCG precies wie het vermoeden heeft en wie het zeker weet.
Dat is de insteek van een poll.
Als je aan kom bij Kia ik denk dat het er tien zijn en tien denken het niet te hebben dan kom je als Club niet echt over.
Als je cijfers hebt vanuit de club kan je dat keihard op tafel leggen bij KMNL.
De Rio rijders moet niet zelf gaan testen of ze het bewuste pakket hebben.
Ga dan naar de dealer dan weet je het zeker.
Ik zie allerlei polls voorbij vliegen maar niet de belangrijkste.
Bij deze een opzetje.
A. Wie heeft het vermoeden geen VSM pakket te hebben.
B. Bij wie is door de dealer geconstateerd geen VSM pakket te hebben.
C. Bij wie is door de dealer geconstateerd geen VSM pakket te hebben en is de claim gemeld bij KIA.nl
D .Wie heeft een bevestiging van KIA NL gehad dat er geen VSM pakket op zit.
Wie kop hem in?
Ik snap dat je baalt, en er moet ook een goede vergoeding komen.
Maar wat ik je al wel kan vertellen is dat die 2000 euro of lederen bekleding hem niet gaat worden, dat zullen ze nooit doen. 1000 euro lijkt mij een mooie vergoeding en die is al aan de hoge kant. Wellicht dat je de koop wel kan ontbinden.
Helaas, via een kennis, die wij hadden aangeraden zo'n mooie Rio te kopen (en dit heeft gedaan!), net als wij hadden, hoorden we van dit verhaal. We hebben het laten checken door hem aan de computer te hangen van de dealer, waarbij ook duidelijk werd dat dit NOT Installed was.
Staat de optie wel in de VIN code?
Als je mijn mening wilt weten... ik geloof niet dat het missen van het VSM paket van enige invloed op de inruilprijs zal zijn.
Net zomin als ik geloof dat je meer dan 500 euro vergoeding zult kunnen krijgen of dat je in het dagelijks verkeer in Nederland überhaupt zult merken of het er al dan niet op zit.
Er zijn opties die veel duidelijker in beeld of hinderlijker bij gemis zijn dan deze VSM optie, zoals gemis van electr. ramen of airco. Het feit dat mensen er soms wel een week over doen om er achter te komen of het er überhaupt al dan niet op zit zegt toch al iets?
Blijft natuurlijk staan dat het een fout van Kia is die niet had mogen gebeuren en dat er daarom iets geregeld moet worden. Ik had het liefst tegen gunstige voorwaarden over 3 maand een nieuwe 2013 auto; een nieuw bouwjaar heb je later heel wat meerwaarde aan.
Denk het ook niet :bergen hebben we hier niet en bij een noodstop kun je ook zelf de knippers aanzetten. ESP zit er bij de meeste wel op en dat is de meest waardevolle optie. Ik denk dat een gratis oliebeurtje wel zo'n beetje het maximum is wat er uit gesleept kan worden.
Vehicle Stability Management (VSM) is a technology featured in the Sportage. It’s a very smart technology that enables the vehicle to stabilize itself when accelerating or braking suddenly on uneven roads and shortens the braking distance.
Here’s a closer look at how the system works. The yaw rate and lateral G sensor (Yaw G Sensor) and wheel speed sensors accurately gauge the vehicle’s movements.
Based on the data gathered by the sensors, the Electronic Stability Control (ESC) and Motor-Driven Power Steering (MDPS) system kick into gear as soon as the vehicle starts sliding to secure vehicle stability.
If a vehicle brakes on an uneven road that has both icy patches and asphalt, the vehicle tends to veer towards the side with a higher friction coefficient (asphalt), while the opposite would happen during sudden accelerations. VSM detects such veering and automatically engages MDPS to help drivers drive safely.
Ik ken iemand die dacht dat hij tweedehands een 4 wiel aangedreven Volvo had gekocht. Pas weken later bij een beurt kwam de monteur erachter dat de aandrijfstang tussen de voor- en achterwielen was weggeslepen :wink: En al die tijd had hij zich erg veilig (en trots natuurlijk) gevoeld.....
